VOX 252 MTI
The VOX 252 MTI is the current highlight in the VOX series. The uncompromising approach, involving fitting the TI 100 8 OHM as the low- to mid-range unit and the MHT 12 8 OHM as the tweeter, worked highly successfully in the TOPAS. Following the basic design concept of the VOX series, this system is fitted with two TI 100 8 OHM 's as low- to mid-range units and the TIW 250 8 OHM as the woofer.
One particularly convenient innovation is used for the first time in the VOX 252 MTI: it is now possible to tune the bass output level on the crossoverunit. Depending on the acoustic properties of the room and personal preference, the bass output might be too strong, if the speakers are placed close to a wall, for example. The adjustment unit is mounted on the crossover unit directly parallel to the woofer and enables to listener to adjust the output level between 70 Hz and 150 Hz. The lower-frequency bass is not affected. Increasing the resistance affects the bass output: 10 ohms for a minimal reduction in bass and 3.3 ohms for maximum reduction. If the adjuster is left open (i.e. resistance is infinite), bass output reduction is deactivated.
Press
With their VOX 252 MTI, VISATON have, once again, created great results. This is not only the best VOX there has ever been, it is, in my opinion, the best sounding VISATON speaker of all. Ready-made speakers of this quality will often cost as much as 10,000 a pair. The DIY concept is definitely a winner here.
Rated power | 200 W |
Maximum power | 350 W |
Nominal impedance Z | 4 Ohm |
Übertragungsbereich (-10 dB) | 28 - 40000 Hz |
Mittlerer Schalldruckpegel | 83 dB (1 W/1 m) |
Trennfrequenz | 200 / 4000 Hz |
Gehäuseprinzip | Bassreflex |
Net volume | 63 l + 4 l (ohne BR-Kanal) |
Außenmaß Höhe | 1150 mm |
Außenmaß Breite | 235 mm |
Außenmaß Tiefe | 400 mm |
