Do you have any questions?
ATLAS COMPACT MK V
Art. No. 5920
Building instruction
Exploded drawing
Assembly
Inside the large subwoofer cabinet there is a separate chamber that houses the low- to midrange unit. The tweeter and mid-range driver are also mounted in this cabinet.
To achieve the broad bevel on the upper third of the front panel, the sides of the low- to mid-range cabinet are doubled-up. Three 8 mm holes will have to be drilled in the rear wall of the low- to mid-range chamber for the cables. These must be well sealed off after the cables have been positioned.
The rectangular opening in the rear wall is for the terminals. The frequency crossover unit is mounted on the wall behind the bass cut-out.
Inner damping
Two mats of damping material are pushed into the low- to mid-range cabinet.The remaining 10 mats are evenly distributed around the woofer chamber.
Cabinet parts list for 1 box
Parts
Size (mm)
Quantity
Material: 19 mm MDF or chipboard
Front panel
1355 x 360
1
Side panels
1355 x 381
2
Top and bottom panel
322 x 381
2
Rear panel
322 x 1237
1
Mid-range bottom panel
322 x 160
1
Mid-range rear panel
322 x 475
1
Mid-range side panels
141 x 475
2
322 x 231
1
Base
322 x 362
1
Brace
322 x 100
1
Brace
362 x 100
1
Brace
141 x 70
1
Brace
202 x 70
1
Crossover
Press
Extract from Stereoplay (MK II)
Overall, the Atlas compact MK II is able "to take enormous leaps in dynamic play and convert them effortlessly into pure sound." " a tempting way to turn that dream into reality and treat oneself to a set of real speakers."
Category: top grade
Verdict: overall winner
Extract from Klang & Ton (MK III)
"It is indeed the drum sections that really make this large Visaton speaker system sit up and take notice. It powers out fiery drum solos across the room ... without even showing the hint of an effort."
Category: top grade 1
Value for money: very good
Contact us
