Do you have any questions?
CT CENTER 170
CT CENTER 170 is based on the CT MAIN 170 main loudspeakers and acts as a Centre Speaker, where the only difference is that it is designed to lie on its side. Since the speaker arrangement and crossover unit are identical in every respect, this centre system is ideal for use with THX® systems. With its linear frequency response of 80 Hz 20,000 Hz in an enclosed cabinet with a total Q-rating of 0.7, the required vertical beaming and a maximum sound pressure of 108 dB, this system leaves nothing to be desired. The loudspeakers used, W 100 SC 4 Ohm and W 170 SC 4 Ohm, are magnetically shielded and the shielding of the complete speaker unit corresponds to THX® regulations (3-Gaussian curve). This means that the entire speaker can also serve as a stand for a TV set. The speaker is a titanium dome tweeter with a neodym magnet. The CT CENTER 170 can also be used as a main loudspeaker and, because of its overall dimensions, can be placed on top of a SUB T-36 subwooferwhich is lying on its side.This speaker has extremely clear bass reproduction with a well-balanced overall sound quality, providing a realistic impression of live sound. Even high volume settings come across naturally and undistorted. The designers placed emphasis on hig impedance, so that the speakers can be connected up to virtually any amplifier with no problems. We recommend using this system in conjunction with CT MAIN 170 main loudspeakers, the CT DIPOL 130effect speaker and the SUB T-36 subwoofer. The realistic soundreproduction especially for films is so close to the original that the listener feels as if they are right in the thick of it. This system is a joy to listen to.
No longer available
Technical Data
Component parts list
Additional Content
Rated power 100 W
Maximum power 150 W
Nominal impedance Z 8 Ohm
Übertragungsbereich (-10 dB) 80 - 20000 Hz
Mittlerer Schalldruckpegel 89 dB (1 W/1 m)
Trennfrequenz 450 / 2500 Hz
Gehäuseprinzip geschlossen / closed
Net volume 21 l + 3 l
Außenmaß Höhe 360 mm
Außenmaß Breite 520 mm
Außenmaß Tiefe 226 mm
Component parts list for 1 box
Tweeter:
SC 4 ND 4 OHM
1 piece
Midrange driver:
W 100 SC 4 OHM
2 pieces
Woofer:
W 170 SC 4 OHM
2 pieces
Crossover:
Weiche CT Main/Center 170
Terminal:
ST 77
1 piece
Damping material:
1,5 bag
Countersunk screws:
3,5 x 25 mm
24 pieces
Cable:
2 x 2,5 mm2
2 m
2 x 1,5 mm2
1 m
Contact us
