Do you have any questions?
SUB T-36
The SUB T-36 subwoofer was developed to complement home video and THX® systems with an active subwoofer output and can, if required, be equipped with an active subwoofer module. The driver used is the TIW 360 8 Ohm, to which a compensating magnet can be added to shield off unwanted magnetism. The 12" speaker used achieves low-range frequency extremes of 35 Hz in this relatively small 63-litre cabinet. From 50 Hz to 200 Hz, the subwoofer produces a perfectly linear frequency response and achieves the THX® requirements with its Butterworth characteristics and an attainable distortion-free sound pressure of over 105 dB at 50 Hz. Used in conjunction with an active filter, the system achieves the required cut-off frequency and filter characteristics with ease and, at the same time, produces maximum sound pressure, of no less than 113 dB with the SUB T-36. If set up in the corners of the room, an additional 9 dB can be added to the rated maximum. Thanks to the special cabinet construction, low-range bass comes across intact, clearly and yet powerfully, so that effects such as explosions are not only clearly heard, but provide the listener with a tangible realistic live feeling, too. The SUB T-36 subwoofer in conjunction with the CineTOP 170 system is recommended for medium sized to large rooms. Lying on its side it can also be used as a base for the CT CENTER 170.
No longer available
Technical Data
Component parts list
Additional Content
Rated power 300 W
Maximum power 600 W
Nominal impedance Z 8 Ohm
Übertragungsbereich (-10 dB) 35 - 200 Hz
Mittlerer Schalldruckpegel 89 dB (1 W / 1 m)
Gehäuseprinzip Bassreflex
Net volume 63 l
Außenmaß Höhe 520 mm
Außenmaß Breite 360 mm
Außenmaß Tiefe 496 mm
Component parts list for 1 box
Woofer
TIW 360 8 Ohm
1 piece
Terminal
ST 77
1 piece
Special wood screws:
5 x 30 mm
8 pieces
Senkkopfschrauben:
3.5 x 25 mm
4 pieces
Damping material:
3 bags
Cable
2 x 2.5 mm2
1 m
Frequency- and impedance response
Contact us
