Do you have any questions?
VOX 252 MHT
Due to the deep starting frequency of the MHT 12 8 OHM it is possible to make use of this magnetostat in the VOX 252. Of course, the crossoverhas to be changed from that used in the original version with its KE 25 SC 8 OHM. Fortunately, the AL 130 8 OHM 's only have to be separated slightly higher which means we are still a long way from the baffleresonance levels. Here, too, the transfer frequency is 3000 Hz. As can be seen from the dotted frequency curves for the individual drivers, the AL 130 8 OHM drop off at 2000 Hz and the MHT 12 8 OHM at 4500 Hz and meet again at 3000 Hz and -6 dB. The magnetostat need not by any means produce its full output at 3000 Hz, as some people often believe. This would not make sense in terms of achieving the lowest possible distortion factor.
Since the front panel of the MHT 12 8 OHM is slightly larger, the AL 130 8 OHM 's have to be spaced a little further apart (10 mm).
As regards their sound quality, both versions (original VOX 252 with KE 25 SC and VOX 252 MHT) are at the same high level. The version preferred by each particular customer will depend on personal taste, the type of music you listen to and how you listen.
No longer available
Technical Data
Component parts list
Additional Content
Rated power 200 W
Maximum power 350 W
Nominal impedance Z 4 Ohm
Übertragungsbereich (-10 dB) 28 - 40000 Hz
Mittlerer Schalldruckpegel 84 dB (1 W/1 m)
Trennfrequenz 200 / 3000 Hz
Gehäuseprinzip Bassreflex
Net volume 70 l + 4 l
Außenmaß Höhe 1150 mm
Außenmaß Breite 235 mm
Außenmaß Tiefe 400 mm
Component parts list for 1 box
Tweeter:
MHT 12 8 Ohm
1 piece
Midrange:
AL 130 8 Ohm
2 pieces
Woofer:
TIW 250 8 OHM
1 piece
Crossover:
VOX 252 MHT
Terminal
BT 95/75
1 piece
Damping material
4 bag
Special wood screws:
5 x 30 mm
4 pieces
Wood screws:
3.5 x 19 mm
12 pieces
Countersunk screws:
3.5 x 25 mm
4 pieces
Material for speaker covers:
width 50 cm
0.5 m
Cable:
2x 1.5 mm2
2 m
2x 2.5 mm2
2.5 m
Frequency- and impedance response
Contact us
